Drained the transmission fluid while the vehicle was running
2005 FORD ESCAPE
200,000 MILES • 4 CYL • 4WD • AUTOMATIC
JAMESHUNT6
I drained the transmission fluid while the vehicle was running but didn't add transmission fluid at the same time so it idled for two minutes empty. Could I have damaged the transmission and what should I do now?
Jul 11, 2019 at 10:26 AM
Good afternoon,
Why did you drain it while running? That should never happen. It is drained with the engine off.
Refill the transmission and drive it and see if it works normally.
You may have damaged the clutches internally but will not know until you drive it.
Jul 11, 2019 at 10:36 AM
