Driving down the road acts like it shifts in to neutral. Changed the shift solenoid, have 2 codes p1762 and p1757.
Jan 31, 2020 at 7:48 PM
CERTIFIED EXPERT
P1762 Dodge | Governor Pressure Sensor Offset Voltage Too High or Low, it looks like the pressure sensor is not working correctly. here is the location so you can check it out/ replace it/ check the connections. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Image (Click to enlarge)
Feb 1, 2020 at 11:21 AM
US95
MEMBER
I replaced the shift solenoid. I'll check out the pressure sensor.
Feb 1, 2020 at 11:33 AM
CERTIFIED EXPERT
good job. please let me know what happens.
Feb 3, 2020 at 10:01 AM
US 25
MEMBER
I changed the solenoid. Filled the tranny fluid. Shifts really good, but put it in drive you have to really give it the gas to take off. It acts like it is pulling a heavy load.
Feb 3, 2020 at 9:54 PM
US 25
MEMBER
So I had to change my username.
Feb 3, 2020 at 9:56 PM
CERTIFIED EXPERT
It seems like the catalytic converter might be plugged. here is a guide to confirm the issue:
