Welcome back:
Is it a different transmission? Was it serviced prior to use? For it to be doing the same thing, something has to be out of adjustment. Take a look through these directions related to the throttle cable replacement. Let me know if this is how you adjusted it.
ON-VEHICLE REPAIR
1. DISCONNECT THROTTLE CABLE
a. Disconnect the cable from the throttle linkage.
b. Disconnect the cable from the cable clamps in the engine compartment.
2. REMOVE PARK/NEUTRAL POSITION SWITCH. Refer to Transmission Position Switch/Sensor
3. REMOVE VALVE BODY. Refer to Valve Body; Service and Repair.
Picture 1
4. REMOVE THROTTLE CABLE
a. Remove the retaining bolt and plate.
b. Pull out the cable from the trans-axle case.
Picture 2
5. IF THROTTLE CABLE IS NEW, STAKE STOPPER OR PAINT MARK ON INNER CABLE
HINT: New cable does not have a staked cable stopper.
a. Bend the cable to ensure a radius of about 200 mm (7.87 inch).
b. Pull the inner cable lightly until a slight resistance is felt, and hold it there.
c. Stake the stopper, 0.8 - 1.5 mm (0.031 - 0.059 inch) from the end of the outer cable.
d. Install a new O-ring to the throttle cable.
e. Push in the throttle cable and install the retaining bolt.
6. INSTALL VALVE BODY
7. INSTALL PARK/NEUTRAL POSITION SWITCH
8. CONNECT THROTTLE CABLE
9. FILL FLUID AND CHECK FLUID LEVEL
10. ADJUST THROTTLE CABLE
a. Check that the accelerator pedal is fully released.
b. Check that the inner cable is not slack.
c. Measure the distance between the outer cable end and stopper on the cable.
-Standard distance: 0-1 mm(0-0.04 in.)
if the distance is not the standard, adjust the cable by the adjusting nuts.
__________________________
Jun 4, 2019 at 8:05 PM
