Transmission not shifting properly
2008 MINI COOPER
130,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JUANM2284
  • 5 POSTS
Hello good morning, I am having problems and I will try to explain it as best I can. The car starts well, makes the changes and I think when it is going to go to my next gear the car accelerates and does not grab the fourth change, it seems as if it were in neutral (N), a Check engine and a sign like a pinion appear.
I put a Scanner for BMW and Mini, I get a code on the transmission part 4F95 (4F95 EGS: Ratio monitoring, 4th gear). I have searched the internet and it tells me that it is something related to the Clutch that is worn.
Can you let me know what the problem may be? I would greatly appreciate it! have a nice day.
May 1, 2020 at 6:16 AM
This could be related to a worn clutch that is slipping but I attached the info from the service manual. It is pointing to a control valve issue in the valve body. This would make more sense then a worn and slipping clutch because a clutch issue normally shudders but the failure to engage is a control issue.
I included the process for the valve body in the event that this proves out. Just let me know if you have questions and we can go from there.
May 1, 2020 at 7:21 PM
JUANM2284
  • 5 POSTS
Hello, thank you very much for your excellent explanation and I will try to solve this problem as soon as possible. Again, thank you very much!!
May 2, 2020 at 5:23 AM
You are welcome. Please keep us updated with what you find. Thanks
May 2, 2020 at 6:40 PM
