Car will not move in any gear
2003 MAZDA 6
150,000 MILES • 2WD • AUTOMATIC
QAZX4234
I can start car runs fine. I can move gearshift to any gear, but car sounds like it wants to move but does not. When I put it back into park it makes a loud noise.
Aug 17, 2018 at 1:25 PM
This sounds like a CV axle is broken at the outer CV joint. Start the car and put in in reverse them look under the car you might need to jack it up a little. If you see one axle turning it is and here is a guide to help you see what you are in for when changing it out:
https://www.2carpros.com/articles/replace-cv-axle
Aug 18, 2018 at 6:40 PM
The loud clunk you hear when you place it in park, is it coming from the transmission? If it is, that may be the parking paw locking into park while the transmission is still turning inside. The first thing I want you to check are the half shafts (front axles) on the vehicle. If you have a broken CV joint, that would be why the car is not moving and the transmission clunks when you put it back into gear. Here is a link that describes its purpose as well as shows a picture of one so you can find it under the front of the vehicle:
https://www.2carpros.com/articles/how-a-cv-joint-works
Let me know what you find or if you have questions.
Aug 18, 2018 at 6:41 PM
QAZX4234
Yes it was a broken CV joint. Thank you so much I just fixed it again. Thank you
Aug 21, 2018 at 12:50 PM
Nice work, we are here to help, please use 2CarPros anytime.
Aug 22, 2018 at 9:48 AM
