I got this vehicle from dad who drove it for about two years. when he purchased it the front drive shafts was removed. The previous owner told him it was because there was a seal leaking. Been driven roughly sixty miles a day since with out a problem like the one it is having now. The only issue it has had ever since my dad got it was it delays shifting into over drive. Usually will not go into over drive until about fifteen miles down the road continuously around sixty mph and even sometimes not at all. Also if it is parked on an incline with it powered off and in park it will slowly role backwards. This model is the Limited Edition v8, has a Quadra Trac transfer case that is all time 4wd. suddenly a couple weeks ago while driving it starting making a horrible grinding and clanking sound that I can literally feel thumping the driver side floor board. checked axles, bearing, ball joints, tires, everything seems fine. upon doing research for days on it. I think it is the transfer case. not sure what in the transfer case it could be. If it is fixable or even worth fixing for that matter. now I make sixty mile round trip to work and back and this is my only vehicle, I am a waitress so I do not have much money and a single mom. I am still driving it because I have no choice right now but it scares me to do so! Is it dangerous to drive? Guess I need so advice all around about it. Thanks in advance!
Sep 1, 2017 at 4:45 AM
