Transfer Case, a howling sound appeared while driving the car?
2012 CHEVROLET EQUINOX
85,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
ALEXBEL
  • 65 POSTS
A howling sound appeared while driving the car. The source of the sound is most likely the Transfer Case (Getrag 760). I am not in the USA. I started preparing for the Transfer Case repair and bought almost all the necessary parts, gaskets and seals in advance. I keep driving around looking for the missing parts. However, I can't identify the numbers of some of the Transfer Case parts. I am using a drawing I found on the internet. I am including this picture here. Can you tell me the part numbers of these parts?
31 - Transfer Case Rear Output Shaft Bearing Assembly.
33 - Transfer Case Rear Output Shim.
35 - Transfer Case Rear Output Shaft Bearing Spacer.
Jul 13, 2022 at 7:36 AM
For internal parts you will need to contact the dealer for part numbers. To get the correct part numbers you will need to have the transfer case ID tag. Check out the diagrams (below). Please let us know what happens. Sorry we couldn't be more help on this.
Jul 13, 2022 at 12:35 PM
