found speedo inop, fuses ok and can see the vss has been changed
I feel if the speedo does not work trans will not shift what controls the speedo
1993 gmc van dura 3500 non turbo diesel all wiring seems good I found an electricla box above the battery two connectors go to it one was unplugged
plugged it in and check all pins for straight and signs of corrosion all ok
May 24, 2013 at 12:55 PM
