Transmission slipping
2002 JEEP LIBERTY
179,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
CANNON1349
  • 861 POSTS
Transmission goes into reverse fine but when put in drive it will not do anything for a few seconds and then it will catch and go, but when given gas it sputters/feels like its disengaging. Reverse, Neutral, and Park work fine. I'm thinking torque converter? The fluid is a reddish brown with some bubbles. Some steam/smoke from dipstick but no burning smell.
May 8, 2020 at 5:02 PM
We should run the codes first, but it sounds like the line pressure sensor has gone out. Here is the location of the sensor and a guide to help you see how to get the codes:
Check out the diagrams (below). Please let us know what you find.
May 9, 2020 at 12:55 PM
CANNON1349
  • 861 POSTS
No codes regarding that sensor. Just some evap codes and an idle control code. Possibly due to a cold air intake on it. Still think it's the sensor?
May 9, 2020 at 1:39 PM
CANNON1349
  • 861 POSTS
I replaced the sensor and now I'm getting P0731 and P0876. Now the transmission won't do anything.
May 9, 2020 at 2:53 PM
CANNON1349
  • 861 POSTS
So I did some research and the most common repairs point to the solenoid pack in the transmission. Which will also include new fluid and filters. What do you think?
May 9, 2020 at 4:36 PM
Hmm, the P0876 trouble code include a low transmission fluid condition, defective high pressure pump, which mean the transmission needs to be rebuilt or get a used one. Here is a video to help you remove the unit on a similar car but the process is the same. I have included instruction on how to remove the transmission in the diagrams below. You can save about $700.00 by removing the transmission yourself.
https://youtu.be/3vJAojsrfuU
May 11, 2020 at 11:00 AM
CANNON1349
  • 861 POSTS
Okay, but why would that code show up with a new sensor? I put the old sensor back in and that particular code went away. But still getting the gear ratio code. Also P0700 , I guess if the solenoid pack doesn't cut it then we'll look at a trip to the junkyard.
May 11, 2020 at 11:13 AM
Here is how you can change the solenoid pack which may fix it. If the pump has failed the transmission will need to be rebuilt. Check out the diagrams (below). Please let us know what you find.
May 11, 2020 at 11:26 AM
CANNON1349
  • 861 POSTS
Would it be possible to convert this to a 2wd car? I went to the junkyard and found a bunch of the 2wd transmissions, but no 4wd.
May 14, 2020 at 12:24 PM
I believe the 2wd will have a longer output shaft so it wont work. You must find a 4wd unit. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
May 14, 2020 at 12:30 PM
CANNON1349
  • 861 POSTS
Here's a video.
May 14, 2020 at 1:11 PM
Thanks for the video it helps. this can be the the fluid pressure sensor. I would try replacing it even though there is no code if that does help the transmission needs to be rebuilt. Please let me know.
May 15, 2020 at 11:18 AM
CANNON1349
  • 861 POSTS
As mentioned above, I didn't get the engine code for the fluid sensor until I replaced it with a new one. I took the new sensor back to the store.
May 15, 2020 at 11:22 AM
Stupid question, have you checked the transmission fluid level? I know you checked the condition of the fluid? If the level is okay the transmission will need to be rebuilt.
May 15, 2020 at 11:53 AM
CANNON1349
  • 861 POSTS
Seemed a little overfilled.
May 15, 2020 at 11:56 AM
CANNON1349
  • 861 POSTS
Besides that the fluid is a bit bubbly. Do you think there's no reason to change the fluid and 2 filters and the solenoid pack? Just grabbing at straws here.
May 15, 2020 at 5:06 PM
It can help to change the fluid and solenoid pack, but there is no way to tell for sure unless the unit is removed and disassembled. So it's a chance you need to decide if you want to take.
May 17, 2020 at 10:20 AM
CANNON1349
  • 861 POSTS
Well, I just got P0944 which points to either a bad pump or clogged filter so either way fluid has to be drained.
May 17, 2020 at 10:23 AM
Let me know if that fixes it.
May 17, 2020 at 10:26 AM
CANNON1349
  • 861 POSTS
I think I may have found the problem. The spin on filter that looks like a motor oil filter was rolling around in the pan. Looks like this is the first time the pan has been off though, it has silicone sealing it. What the heck?
May 17, 2020 at 2:34 PM
CANNON1349
  • 861 POSTS
No I'm wrong. This isn't the first time this has been done. The filter number is TF98 which is an AutoZone part number.
May 17, 2020 at 2:36 PM
CANNON1349
  • 861 POSTS
Well, correctly tightening the new spin on filter with a new suction filter and fluid fixed it. What a weird situation, I was sure it was the hydraulic pump! Guess no filter let the PSI drop to 0.
May 17, 2020 at 5:19 PM
Nice work, we are here to help, please use 2CarPros anytime.
May 18, 2020 at 10:00 AM
