Good morning.
Below are the descriptions and possible causes for the failures. In most cases, it is a wiring issue.
SYMPTOM
P0743-TORQUE CONVERTER CLUTCH SOLENOID/TRANS RELAY CIRCUITS
WHEN MONITORED
Continuously with the key on.
SET CONDITION
This code will set if the voltage detected on the Torque Converter Clutch Solenoid Control circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
- TCC solenoid control circuit open
- Fused B+ circuit open
- TCC solenoid control circuit short to ground
- Transmission relay output circuit short to ground
- TCC solenoid control circuit short to voltage
- TCC solenoid control circuit short to other circuits
- Transmission control relay output circuit open
- Torque converter clutch solenoid
- Transmission control relay - poor contacts
- Powertrain control module
- Intermittent wiring and connectors
753
SYMPTOM
P0753-TRANS 3-4 SHIFT SOL/TRANS RELAY CIRCUITS
WHEN MONITORED
SET CONDITION
This code will set if the voltage detected on the 3-4 Shift Solenoid Control circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
- P1765 DTC present
- 3-4 shift solenoid control circuit open
- 3-4 shift solenoid control circuit short to ground
- 3-4 shift solenoid control circuit short to voltage
- 3-4 shift solenoid control circuit short to other circuits
Jul 30, 2018 at 3:26 AM
