Absolutely, this is likely related to electronics. Chances are it is related to the transmission control module.
If all the lights are staying on, you really need to start by scanning the can-bus.
CAN stands for controller area network. Basically, all computers and modules are tied together via a few wires and communicate with each other.
This type of scan will retrieve codes regardless of the module storing them. A basic scan tool won't do this.
Here is a link showing how it is done.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Also, you can reset the transmission control module, but it does require a scan tool that can communicate with it. I don't know if you have one or not. There was actually a technical service bulletin out indicating this needs done. I attached it below. However, I don't know if it would prevent shifting altogether. Take a look through it.
See pics below.
Mar 11, 2022 at 7:10 PM
