Thanks for the update. A delay in reverse (which requires the highest line pressure) can simply be the result of the fluid condition in extreme conditions. By chance, were you able to check for codes?
I'm starting to question the shift linkage. On 4-Speed automatics, it is possible to drive the vehicle in 3rd gear rather than "overdrive" and not perceive it. Typically, this condition occurs when the shift indicator or the shift linkage/detent is misadjusted. Misadjusted shift linkage can also result in improper signals to the ECM, which can result in less spark advance, and results in a drop in fuel economy.
I'm questioning this because what happened that seems to have led to the issue shouldn't have caused this to happen. Running for less than 5 seconds wouldn't have emptied the fluid.
Do me a favor. Let's see if the shift linkage is out of adjustment. When you were working on the vehicle, anything could have happened.
If you look at the pics below, they explain how to adjust the linkage on this vehicle. Take a look through them and let me know if you are comfortable performing them. Additionally, I am making the assumption that this is an S-10 Blazer and not a full size. If that is incorrect, please let me know.
I will watch for your reply.
See pics below.
Feb 26, 2022 at 7:13 PM
