Changed CV axle, seal, hub bearing, motor mount, and still have transmission fluid leak.
Feb 9, 2018 at 9:13 AM
CERTIFIED EXPERT
Where does the leak appear to be coming from?
Feb 9, 2018 at 9:58 AM
KEVIN ROSENBUM
MEMBER
CV axle into transmission passenger side.
Feb 10, 2018 at 6:55 PM
CERTIFIED EXPERT
Okay, thanks.
There is a seal at the transmission for the axle. it is called a bulk head seal. you need to remove the axle again and use either a seal puller or a large screw driver with an angled end. then be careful installing the new one as not to damage it. then install the axle.
Feb 11, 2018 at 12:31 AM
KEVIN ROSENBUM
MEMBER
So there is more than one seal you are telling me? thanks.
Feb 11, 2018 at 5:59 AM
CERTIFIED EXPERT
No, only one seal for that axle. there is another seal for the axle on the other side as well.
Feb 11, 2018 at 2:13 PM
KEVIN ROSENBUM
MEMBER
Already changed seals.
Feb 11, 2018 at 7:24 PM
CERTIFIED EXPERT
If they are still leaking, then there is another issue inside the transmission is a bushing that supports the axle shaft, if it is worn, there will be play in the shaft and that will cause the seal to leak.
