transmission not shifting properly
2001 FORD E-SERIES VAN
250,000 MILES • 4.6L • 6 CYL • 2WD • AUTOMATIC
RICHARD PETERS
shifting fine when taking off slowly but hanging up when going faster. also will not go into passing gear.
May 16, 2021 at 6:47 PM
Good morning,
This could be several reasons for this. I attached a flow chart for the symptoms for you. You will need to check the line pressure to be sure the front pump and seals are working correctly.
https://www.2carpros.com/articles/automatic-transmission-problems
I would start by changing the fluid and filter. If the filter is clogged, it could cause this issue.
May 17, 2021 at 1:58 AM
