Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Trailblazer
Engine Cooling
Water Pump
Replace/Remove
Replaced water pump now transmission is not shifting properly
2004 CHEVROLET TRAILBLAZER
155,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
JAMES SPRY
MEMBER
FOLLOW
I changed my water pump and then I started having transmission shifting problems.
Feb 20, 2018 at 12:53 AM
CERTIFIED EXPERT
Good morning.
There is no connection between the repair and the transmission shifting.
Check the connection at the throttle position sensor on the throttle body for any loose or damaged pins.
Is the check engine light on?
Feb 20, 2018 at 1:48 AM
JAMES SPRY
MEMBER
Roy thanks, but where is the throttle body positioning sensor at?
Feb 20, 2018 at 2:24 AM
JAMES SPRY
MEMBER
Check engine light is on.
CERTIFIED EXPERT
Okay, can you get me the code that is set?
It is located on the side of the throttle body. That is where the air goes into the engine from the air filter.
Feb 20, 2018 at 2:48 AM
