I'm trying to get help here. The car listed above just stopped. The shop said transmission is bad. I jacked it up and pulled the drain plug completely "cold" nothing came out. (Normally I know a car should be hot, switch through all gears several times, then pull plug to verify fluid). But here it was cold, no fluid, pulled pan and maybe there is 1 quart to 2 max... Pan also has thick gray sludge especially on magnet area. Trying to understand if this would cause transmission failure to engage (due to lack of fluid and pressure)? Also, if filled would it resolve the problem? Any other suggestions/tests?
Jan 4, 2022 at 9:00 AM
