Tranny issue
1992 EAGLE SUMMIT
136,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
NATHANAEL DILL
When gearing up if I don not have momentum going uphill it seems to not want to grab, it also keeps using automatic transmission fluid, however I have never seen any on the ground under the vehicle is it possible there might be a simple fix that will not required a new transmission or a expensive remove and rebuild?
Apr 24, 2016 at 2:36 AM
HMAC300
  • 48,601 POSTS
have a trans guy look at this the fluid may be leaking into radiator or one of the lines and is dripping on to car s you just can't see ityet.
Apr 24, 2016 at 2:15 PM
