Alright so I bought a the car listed above it is a GT. about three weeks ago the guy said the overdrive solenoid are bad. But drives fine with overdrive off. So i do that. I can shift into first and second fine but it will not go into third unless i turn over drive off then it acts like its in neutral. it revs up a little bit then I turn it back off then it shifts into third but after a little bit the engine starts to over heat. I replaced the whole distributor. still does it. also, I do not know much about cars.
Mar 17, 2017 at 1:12 PM
