Vehicle will not move with the transmission shifted into in any gear?
2002 FORD EXPLORER SPORT TRAC
152,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
KEPNER
I drove it one day, the next day wouldn't move i put in all the gears.
Jul 3, 2020 at 3:43 AM
Good morning,
The first thing to do is to check the fluid level.
https://www.2carpros.com/articles/automatic-transmission-problems
If that is okay, then I would drop the pan and change the fluid and filter as the filter may be clogged with debris.
Beyond that, it could be either the front pump or the torque converter that has failed. That would require removal of the transmission and inspection.
Jul 3, 2020 at 4:49 AM
