had to drop valve body to replace now I can't get the valve body back together
2000 DODGE CARAVAN
87,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DENNISGALEN
Replaced neutral safety switch had to drop valve body to replace now I can't get the valve body back together. some retainers came out and some type of little balls. need diagram on valve body to see where these parts go.
Mar 15, 2020 at 8:23 AM
STEVE W.
  • 15,113 POSTS
This should help, it's the check ball and retainer as well as other parts in the valve body.
May 21, 2021 at 3:05 PM
DENNISGALEN
Thanks Steve, this will help a lot.
STEVE W.
  • 15,113 POSTS
You are welcome. If you need anything else just ask. Thank you for using 2CarPros.
