Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lincoln
Mark VIII
Drivetrain
Transmission
Symptoms
Not Shifting
Transmission trouble
1993 LINCOLN MARK VIII
140,000 MILES • 4.6L • V8 • AUTOMATIC
SHERRY SEYMORE
MEMBER
1 POST
FOLLOW
It does not shift into second or third, but the fluid looks good.
The oil stays clean between changes.
Nov 11, 2017 at 4:19 PM
CERTIFIED EXPERT
It sounds like you have a shift solenoid that is shorted out and not working.
Here is a guide to show you how to remove the pan so you can change the solenoid out:
It is the solenoid with the purple and orange wire.
You will need to lift the car up safely
Nov 13, 2017 at 11:26 AM
