I have the car listed above ST model. Recently it was lacking power, and I found that it was down 7psi (from 22psi it sits at 15psi). if I keep it between 3,500 rpm and 4,500 rpm for ten to fifteen seconds the check engine light will start flashing and if i try to accelerate the car will start to jitter and maintain its pace, if I slow down and switch to first the issue goes away. just tonight i pushed the pedal all the way down when this happened and the rpm began to climb at about 1,500 rpm a second, and i could tell something was slipping (not the tires). Also, the car has a salvage title, but the damage go past the bumper bar.
Jan 9, 2019 at 10:52 PM
