Tramission not going into reverse when engine is cool
2007 TOYOTA CAMRY
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
WIZBONE
After changing the drive shaft of my car yesterday, while my engine is cool it does not go into reverse. I have to put on drive before going to reverse for it to work.
Oct 7, 2018 at 7:59 AM
Good morning.
Did you check the transmission level?
I would start by changing the oil/filter in the transmission. It may be dirt in the filter.
Oct 7, 2018 at 8:39 AM
WIZBONE
Okay, will try that today.
Oct 7, 2018 at 4:44 PM
Sounds like a plan.
Oct 7, 2018 at 4:51 PM
WIZBONE
Thank you very much. I change the oil and back to normal, thanks a lot.
Oct 8, 2018 at 1:44 PM
You are welcome.
Always glad to help.
Oct 8, 2018 at 1:45 PM
