It will come on now and then light an beep, and it will pull to the right like brakes slammed on.
Aug 11, 2023 at 4:06 PM
CERTIFIED EXPERT
Okay, i would lift the front end and grasp the right front wheel to see if the bearing hub is loose and if so, this is what is causing the problem of the transaction control light and the pull to the right.
