Traction control and hill descent control warning lights
2013 HYUNDAI TUCSON
43,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
MARK87
  • 61 POSTS
While driving the car listed above ix35, all of a sudden the traction control and hill descent control warning lights came on. I have switch off the car and started it again but the lights remains on. Is it a bad wheel speed sensor?or some wiring problem? Just like to know where first i should diagnose the problem.
May 7, 2020 at 4:53 AM
Good morning,
There is a fault code stored in the ABS module for this issue. I need that code.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
You can go to a parts store and they will read it for free. Once I know the code, I can narrow the area of failure for you.
Yes, it could be a speed sensor but there are many components in the system.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
May 7, 2020 at 5:51 AM
MARK87
  • 61 POSTS
After arriving to my destination I switched off the engine and restarted it again. the warning lights were gone, but still I went on to put the scanner( Autel al619) and there was no code found..
May 11, 2020 at 10:40 AM
That is because the ABS resets every time you turn it off.
You need a scan tool that can read history codes for the ABS system.
Try accessing the ABS module with your scan tool and see if there are any history codes stored.
May 11, 2020 at 10:50 AM
MARK87
  • 61 POSTS
I found a code "C1513 brake switch error" after accessing the ABS system.
May 13, 2020 at 9:59 AM
Okay, below is a description and flow chart for the code. It is related to the brake switch control circuit.
Electronic Stability Control
C1513 Brake switch error - Scantool Diagnostics
Monitor GDS Data
1. Connect scantool to Data Link Connector(DLC)
2. Ignition "ON" & Engine "OFF".
3. Press the brake pedal.
4. Check the service data related to "Brake Switch" on the GDS.
Specification :The brake switch's signal changes from OFF to ON.
5. Does the service data change normally?
C1513 Brake switch error - Component Inspection
Terminal and Connector Inspection
1. Many malfunctions in the electrical system are caused by poor harness(es) and terminals. Faults can also be caused by interference from other electrical systems, and mechanical or chemical damage.
2. Thoroughly check connectors for looseness, poor connection, bending, corrosion, contamination, deterioration, or damage.
3. Has a problem been found?
Signal circuit inspection
Signal circuit inspection (brake pedal isn't pressed)
Open or Short Check
1. Ignition "ON" & Engine "OFF".
2. Measure voltage between brake light switch (brake switch) terminal of the HECU harness connector and chassis ground.
Specification :Brake light switch - 0V
Brake switch - B+
3. Is the measured value within specifications?
Signal Circuit Inspection (brake pedal is pressed)
Open or Short Check
2. Press the brake pedal.
3. Measure voltage between brake light switch (brake switch) terminal of the HECU harness connector and chassis ground.
Specification :Brake light switch - B+
Brake switch - 0 V
4. Is the measured value within specifications?
May 13, 2020 at 10:07 AM
MARK87
  • 61 POSTS
During a detailed inspection on wiring I found the connector on the brake switch to be loose and one of the wires has some chaffing on it. Had to repair the wire and secure the connector.
May 30, 2020 at 11:06 PM
Okay, did the lights go out and everything return to normal?
May 31, 2020 at 3:31 AM
MARK87
  • 61 POSTS
Yes, everything back to normal. many thanks.
May 31, 2020 at 5:10 AM
You are welcome.
Always glad to help.
May 31, 2020 at 5:22 AM
