traction control
2000 ROVER 75
86,000 MILES • 1.8L • 6 CYL • 4WD • MANUAL
LEE SKELLAND
I have a traction control light on dash. my front passenger wheel moves side to side when parked.
Jun 23, 2017 at 6:11 AM
STEVE W.
  • 15,113 POSTS
That is a very dangerous thing. It sounds like wheel bearing/hub or possibly ball joints. It is not something that can wait to be repaired. It is very possible for the wheel to fail and that would not be good.
Jun 23, 2017 at 11:11 AM
LEE SKELLAND
How would I no what it is without taking to garage
Jun 23, 2017 at 12:49 PM
STEVE W.
  • 15,113 POSTS
Jack it up and support it on jack stands, then move the wheel/tire and look for where the motion is. If you have motion when you push in/out on the top/bottom (12 and 6) of the tire but not in other directions it's likely ball joints. If it moves only when you try to move it at the front/back (3 and 9) on the tire it is more likely tie rod related.
If you can move it in every direction it is most likely a wheel bearing. But those are only a rough guide. If it has much motion the failed part(s) should be readily apparent. Then it is somewhat simple to replace them.
Jun 24, 2017 at 12:36 AM
LEE SKELLAND
Thanks.
Jun 24, 2017 at 4:39 AM
STEVE W.
  • 15,113 POSTS
You are welcome, just be sure to get it repaired. they can cause a lot of problems if they break free.
Jun 24, 2017 at 3:27 PM
