Try to start the car after sitting for over a week and it would not start on the first attempt. On second attempt it started. I went somewhere where I had to wait and the car idled for some time. I turned the car off and it set there for about 15 minutes. I started the car to cool off and it idled for about 10 minutes, I turned it back off and it set there for about 15 minutes. I started the car to cool off and it idled for about 10 minutes, I turned it back off and it set there for about 15 minutes. I started the car to cool off and soon after the traction light came on and a little while later the theft light came on. I turned the car off and the key would not turn all the way to off. I drove the car home and went on to the internet and I found a posting that said to key the key out I would have to reset the system. I turned the key to aux, removed the ECM fuse and then the theft fuse, waited about a minute, replaced the ECM fuse and then the theft fuse, cranked the car, let it idle for about 30 seconds, turned the car off and the key came out and the lights went out. After restarting the car about 30 seconds later the same lights came on. Help!
Jun 18, 2020 at 11:54 AM
