TPS sensor, rough idling and high idle when parked?
1995 NISSAN TRUCK
200,000 MILES • 3.0L • 6 CYL • 4WD • MANUAL
VERONICA RODRIGUEZ
  • 6 POSTS
rough idling and high idle when parked. Checked for vacuum leaks and timing and all is fine. What is the position supposed to be?
Jun 3, 2025 at 8:22 PM
It can be you have an EGR valve that is leaking internally. Here is a video to help you test it to see if this is the problem, also here is the location of the valve as well.
https://www.youtube.com/watch?v=DqUCbbKdWf4
Jun 5, 2025 at 12:34 PM
