if this sensor goes bad will it shut down fuel flow
Apr 25, 2013 at 7:05 AM
JDL
CERTIFIED EXPERT
It won't shut down the fuel pump, as far as I know. If your having fuel issues, check fuel pressure.
What kind of problem are you having? What makes you think the tps has a problem?
Apr 25, 2013 at 7:47 AM
RONNIE GROVER
MEMBER
When it's cold, will crank right up and run fine. After warm up, skips and sputters like it has jumped time when you try to accelerate
Jan 14, 2018 at 5:00 PM
CERTIFIED EXPERT
it sounds like you have an engine coolant temperature sensor that has gone out but to be sure can we run the codes to see what come up? Here is a guide to help us get started.
