TPS and Clutch, gear shift not being able to get in the gears?
1997 TOYOTA TACOMA
120,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
FLORANG2123
  • 10 POSTS
I was having a problem with my gear shift not being able to get in the gears as if it was locked up. But I took the opportunity to swap the TPS because I got a code for it. After replacing it, I start the engine and after the acceleration drops after the initial ramp up, it shuts off. I don't know what the issue could be.
May 17, 2025 at 11:59 AM
There are two separate issues, please start a new thread for the TPS sensor issue, for the clutch problem it sounds like the clutch disc has fallen apart or the throw-out bearing is seized not allowing it to disengage. Can you shift the gears when the engine is not running? If so, this is a sign of the aforementioned failures.
Please go over this video and guide to help confirm the problem:
https://www.youtube.com/watch?v=EpBMj5ZY_bo
and
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Please upload videos of the problem in your response.
May 18, 2025 at 7:06 PM
