TPMS wont reset?
2019 VOLKSWAGEN POLO
100,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
NAZEER.K
TPMS wont reset?
Nov 11, 2025 at 2:36 AM
I would make sure the tires have the right amount of air in them or the system will not reset,
Method 1 - via infotainment screen (most 2019 models):
Inflate all tires to the placard pressure (usually 2.3 - 2.5 bar / 33-36 psi).
Turn ignition ON (engine running or not).
On the center display: MENU - CAR - Tyres - SET
Confirm “Store tire pressures?” choose YES.
Drive for about 5-10 minutes above 25 mph (40 km/h) to complete calibration.
Method 2 - with a physical “SET” button (base trim):
Ignition ON, car stationary, all tires correctly inflated.
Press and hold the SET button (usually near gear lever or glove box) until you hear a chime or the light flashes briefly.
Drive a few minutes to finish calibration.
If this doesn't work I would use a CAN scanner to see which sensor is misbehaving. This video can help
CAN SCAN - https://youtu.be/u-4syLc-ifQ
this guide may shed some light on the issue as well
https://www.2carpros.com/articles/low-tire-indicator-warning-light
Please upload a short video in your response of the problem, so I can see what's going on :)
Nov 11, 2025 at 11:11 AM
