tpms - tire pressure has been checked?
2022 NISSAN FRONTIER
27,000 MILES • 6 CYL • 4WD
Tire pressure has been checked and correct. Low tire alert is on but it shows tire pressures. Bought a tpms reset device. But can't find a reset button or wire to ground for reset. Drove truck but no reset. Have watched several youtube videos but no luck on finding reset button. vehicle is a forntier 2022 sv model.
Dec 2, 2025 at 2:25 PM
There is NO reset button, NO reset wire, and NO ground terminal on 2022+ Frontiers. Nissan moved fully to an auto-learn TPMS system that uses wheel speed + RF signal, and the BCM handles learning. Did you have the tires rotated or does the truck have aftermarket wheels? both of these can cause the TPMS light to come on. I would double check the air pressure in the tires with a digital gauge, they should be 36 psi cold or above. Then if the light stays on you will need to scan the TPMS to see which sensor is not working, (very common) Here is a CAN scan video that will show you which sensor it failing
CAN SCAN - https://youtu.be/u-4syLc-ifQ
Let us know what you find. Ken
Dec 3, 2025 at 10:11 AM
