Hi all, my car listed above (NCT) failed for CO emissions high at high Idle, everything is fine except CO emission. CO emission at low idle is passed. As per Toyota dealer mechanic recommendation Exhaust back box and air filters were replaced with new one, but CO emission test failed again for same reason. Can anyone suggest what might be the reason for this issue. following are the test results.
First time test results:
Low Idle (779 rpm): CO: 0.23%
HC: 66 ppm
High idle (2780 rpm): Lambda: 0.99
CO: 0.55%
HC: 102 ppm
Second time test results:
Low Idle (780 rpm): CO: 0.02%
HC: 36 ppm
High idle (2680 rpm): Lambda: 1.02
CO: 0.51%
HC: 114 ppm
Can anyone suggest what might be the reason for this issue?
HC: 66 ppm
CO: 0.55%
HC: 102 ppm
HC: 36 ppm
CO: 0.51%
HC: 114 ppm
Oct 22, 2017 at 5:29 AM
