2007 Toyota Tundra Serpintine Belt
2007 TOYOTA TUNDRA
MANNR
2007 Toyota Tundra V8 Four Wheel Drive 45000 miles
Where is belt tensioner located and is used with drive socket and if so what size
Aug 9, 2009 at 9:04 AM
KHLOW2008
  • 41,814 POSTS
Hi Mannr, Thank you for the donation. Here are the diagrams for the serpentine belt. I do not have the data of the bolt size and it should be either 14mm.
https://www.2carpros.com/forum/automotive_pictures/192750_BeltTensioner07Tundra3UZFEFig10_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_BeltRouting07Tundra3UZFEFig011_1.jpg
REMOVE V-BANK COVER SUB-ASSEMBLY REMOVE NO. 1 ENGINE UNDER COVER REMOVE FAN AND GENERATOR V BELT. While turning the belt tensioner counterclockwise, align the service hole for the belt tensioner and the belt tensioner fixing position, and then insert a bar of ø 5 mm (0.197 in.) into the service hole to fix the belt tensioner in place. HINT: The pulley bolt for the belt tensioner has a left-hand thread.
Aug 9, 2009 at 9:46 AM
