2003 Toyota Tundra Towing
2003 TOYOTA TUNDRA
99,000 MILES • V8 • 4WD • AUTOMATIC
JRICKTOYOTA
I want to pull my tundra on a 2 wheel dolly behind my moving truck. Can I do it without removing the drive shaft?
Thanks!
Jul 27, 2010 at 7:42 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
For an extended tow, you will have to remove the drive shaft.
mark (mhpautos)
Jul 27, 2010 at 7:52 AM
JRICKTOYOTA
thanks for your help!
Jul 27, 2010 at 7:58 AM
MHPAUTOS
  • 31,937 POSTS
Just to clarify this, with the drive shaft turning and the engine off, there is no oil lubricating main shaft bushes and bearings, as the torque converter drives the oil pump, you run a high risk of damaging a bush or a bearing with lack of long term lubrication, I did meant to add this to the first post but got side tracked.
mark (mhpautos)
Jul 27, 2010 at 8:06 AM
