Stalls at idle
2002 TOYOTA TUNDRA
91,000 MILES • V8 • 2WD • AUTOMATIC
SLINDBLOM
Engine stopped running in drive while coming to a stop. Restarted several times without any problems, but each time I put it in Drive the engine would stop. Finally, after about 8 times it stayed running in drive.
Mar 21, 2009 at 6:45 PM
RACEFAN966
  • 5,029 POSTS
This is common when the IAC valve needs service here is a video that will show you how to fix it.
https://youtu.be/XMB16Gg-qNg
Mar 25, 2009 at 10:02 AM
TUNDRADOG
i have a 2001 tundra 4.7 v8 when the truck gets warmed up it will not idle but sometimes it will but real low it will also die when i am stopping at a light or stop sighn.
Apr 25, 2020 at 1:18 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Hi there,
The engine idle is controlled by the ECU, if there is a problem check for any unresolved fault codes, ICM faults, and vacuum leaks, start here.
Mark (mhpautos)
ANAKI
changed fuel filter but still stalls
Apr 25, 2020 at 1:19 PM (Merged)
Do you have a check engine light?
Check the actual fuel pressure with a guage and comeback with the readings-we start here
ANAKI
I ended up servicing the idle air control valve and fixed it.
Good, job use 2carpros anytime
