2001 Toyota Tundra Power Sterring Pump
2001 TOYOTA TUNDRA
13,200 MILES • 6 CYL • 2WD • AUTOMATIC
BUSTER CHEEK1
Power Steering Pump is making a winding noise as you drive or the truck is at a idle. It is full of power sterring fluid. Should I replace the pump or filters to the pump. If you replace the filters to the pump will the winding noise stop. what makes the winding noise.
Feb 3, 2010 at 11:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
that's possible, another issue may be air in the system. take off the PS resevoir cap and work wheels back and forth to work out the air. fill up PS fluid as needed and see if it helped. if neither helps then could just be a failing pump.
Apr 22, 2010 at 9:53 PM
