2001 Toyota Tundra oil pressure running low and engine temp
2001 TOYOTA TUNDRA
80,000 MILES • V8 • 2WD • AUTOMATIC
KEVINIRVIN
I've just noticed that my oil pressure guage is running significantly lower than normal at both idle and running. At the same time, my engine temperature is running dangerously high. I checked both coolant and oil levels and both are ok. Yesterday I again checked everything replaced caps and everything returned to normal only to return the the above mentioned levels after just a couple of miles today. What do you think?
Sep 2, 2010 at 3:24 PM
Check the oil pressure with a mechanical gauge and test the engine coolant temperature sensor.
Sep 2, 2010 at 3:29 PM
