2001 Toyota Tundra
2001 TOYOTA TUNDRA
137,876 MILES • V8 • 4WD • AUTOMATIC
TERRY FULTON
i have a 2001 toyota tundra and the pedal goes to floor unless pumped once or twice then goes back up. have new master cylinder, new calibers, new pads, new rotors, have bled entire system twice, whats the problem help!!!
Jul 24, 2010 at 10:50 AM
MERLIN2021
  • 17,250 POSTS
Still air in the system, does it have disc all around or drum in the back? Have you inspected the caliper seals for leaks? I just peel the dust boot back to see if fluid pours out... Have an assistant pump the pedal slowly and hold, then crack the lines on the master, listen for air, when only fluid comes out, bleed at the corners(wheels). Dont let the master run dry!
Jul 24, 2010 at 10:59 AM
