I am hearing a whum-whum somewhere around the differential when I am decelerating between 50 mph and 30 mph. I rotated the tires and no difference. I then went to the rear u-joint and changed it with no difference. I then raised the rear wheel wheels off the ground and put it in gear and reved the accelerator. I then heard a similar noise coming from the differential so I put my screwdriver to the left side of the diff. and listened and then put it to the other side and listened. There was no difference in sound from one side to the other, I was thinking of a wheel bearing but I thougtht I would hear a big difference from one side to the other with the bad bearing being louder. What do you think?
Nov 30, 2009 at 7:18 PM
