94 Toyota Tercel heater question
1994 TOYOTA TERCEL
EJSTEINN
I have a 94 Toyota Tercel with 90K miles and the heater does not blow hot air. The engine temperature guage goes up to a normal temp, but there is very little heat coming into the car. The fan works fine, too. We replaced the thermostat, but think it was faulty since the engine temp guage went high with that thermostat, so we put the old one in. We also did a cooling system flush. What things do we need to check? It's getting cold here in CT!
Nov 19, 2007 at 9:54 AM
FISHERMAN
  • 937 POSTS
[quote:71f301847e="ejsteinn"]I have a 94 Toyota Tercel with 90K miles and the heater does not blow hot air. The engine temperature guage goes up to a normal temp, but there is very little heat coming into the car. The fan works fine, too. We replaced the thermostat, but think it was faulty since the engine temp guage went high with that thermostat, so we put the old one in. We also did a cooling system flush. What things do we need to check? It's getting cold here in CT![/quote:71f301847e]
hello !!
Well check the heater core and flush it (could be plug) do it with care because if its to old the flush could cause a leak! ..
Also check the valve that allow the hot water to enter in to the heater core (follow the hose that goes to it)
good Luck!
Nov 19, 2007 at 9:58 AM
