90 Toyota Tercel 3E- Cooling fan stays on after Weber instal
1990 TOYOTA TERCEL
MADDOG2020
I replaced the variable venturi carburator with a Weber conversion 32-36 DGVE Kit# 751
I unhooked and pluged all of the vacuum hoses and electrical connections that went to the old carb and old air cleaner..
I ran a new PCV hose to the vacuum boost/brake line.
Coupled together the coolent hoses that went to the old carb.
Installed a breather hose from the breather hole -on top of the valve cover - to the new air cleaner.
Installed a "T" in the breather hose and connected the old hose from the EGR tube.
Runs great but now the coolent fan stays on continually..
Any suggestions??
Feb 27, 2006 at 4:51 PM
FISHERMAN
  • 937 POSTS
check the cooling fan relay....
Mar 1, 2006 at 9:26 AM
