I lost my head lights.
NO high beams, NO diped or low beams. NO running lights, Thats the ones that come on when the car is started and the hand brake is off.
All other lights are OK. including the marker orange lights / parking lights, indicator, turn and back up lights are fine.
I have checked all the fused I can find which are the ones beside the windshield washer filler in the front left of the enging compartment. there is a "dimmer' and another relay and four 10 Amp fuses for the left, right,high and low beams.
The main fuse box in front of the left hand wheel well in the engine compartment.
The fuse box on the left of the drivers seat under the dash board near the hood release handle.
I have visualy checked for loose or damaged wireing.
There is 12 volts going to the toggle switch that switches on the head lights.
The High / low / High beam flasher has not effect.
Please help.
paul
Please help.
paul
Sep 19, 2008 at 1:02 PM
