1996 Toyota Tercel egr valve
1996 TOYOTA TERCEL
215,000 MILES • 4 CYL • FWD • AUTOMATIC
DIAMON
my 1996 toyota will not pass emissions i was told it probably is my egr valve is it possible to clean it out i do not want to buy a new one and find out thats not the problem
Oct 15, 2008 at 9:41 AM
BMRFIXIT
  • 19,053 POSTS
Yes you can remove and clean the egr valve ,also make sure you clean passeges inside the manifold
do you have check engine light on
if so scan it for codes and let me know what you have for codes
most common is a vacuum switch under the intake manifold
check vacuum hoses
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 16, 2008 at 5:21 AM
