On this CV axle there should be a snap ring at the end. To remove the snap ring you will have to use a snap ring plier to safely remove that ring.
Without the proper tool it will be difficult to remove.
There is also a cotter pin that you will have to remove before taking off the axle nut to get to the CV axle.
Here is a helpful article:
https://www.2carpros.com/articles/replace-cv-axle
I have attached the replacement procedure as well as assembly and disassembly procedure for your reference.
Thank you.
Sep 3, 2021 at 11:20 AM
