1994 Tercel will not turn over
1994 TOYOTA TERCEL
DGOTTSHALL
1994 Tercel, 102K, will not turn over. Plenty of juice to turn on lights and car runs fine if push started (standard transmission). I have tried all gears, neutral, clutch down etc...Is there a safety switch that goes bad?
Sep 20, 2007 at 5:33 AM
SERVICE WRITER
  • 9,123 POSTS
IF you put it in neutral, and hot wire/jumper the starter, you'll eliminate the starter.
There is a neutral saftey switch, sometimes called a clutch switch that may be bad like you think, the parts store will know what you mean...may be a dealer part.
Sep 20, 2007 at 7:36 AM
