1993 Toyota Tercel engine miss
1993 TOYOTA TERCEL
72,000 MILES • 4 CYL • FWD • AUTOMATIC
TBIRD
I have a 93 Toyota Tercel, I replaced cap, rotor,plugs and wires but No.4 cylinder still misses. The plug at No.4 was black others were white, could it be the injector or timing belt as someone told me?
Jan 9, 2008 at 1:34 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
The black is unburnt fuel, three reasons, poor spark, excessive fuel, low compression. You can have the ignition system tested on a oscilloscope, a compression testis a quick check, and the injector would be a suspect if the other two were ok. See how you get on.
Mark (mhpautos)
Jan 9, 2008 at 1:51 AM
