how do i remove drum from rear brakes trying to get car back on the road for work car
Sep 29, 2010 at 2:19 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
raise and support vehicle safely. remove the wheel/tire assembly. remove the grease cap , cotter pin, nut lock and bearing nut. remove brake drum, outer bearing and thrust washer as assembly. to remove drum, turn the parking brake shoe adjuster to release the shoes from the drum .
