1991 Toyota Tercel Valve Cover Gasket
1991 TOYOTA TERCEL
260,000 MILES • 4 CYL • FWD • MANUAL
1991TOYOTATERCEL
I want to try replacing my valve cover gasket (diagnosed as bad by a garage). Are there/What are the torque measurements for putting the valve cover back on?
Oct 26, 2010 at 11:49 AM
BILLYMAC
  • 2,204 POSTS
You can get the torque specs from a service manual. the important thing is that you don't over tighten this will cause damage to the gasket.
just tighten them down snug not to tight. be sure when you put the cover back on the gasket does not move look at the gasket after you sit the cover on make sure it is in the cover all the way around
Oct 26, 2010 at 12:11 PM
