1991 Toyota Tercel smokes
1991 TOYOTA TERCEL
154,322 MILES • 4 CYL • 2WD • MANUAL
BIG SHANE
the car run good has not lost power but it has blue smoke when u crank it and if u reve it up it smokes done compression test and it good
Sep 7, 2008 at 1:01 PM
LEGITIMATE007
  • 5,121 POSTS
you could still have cacked valve oil seals causing the oil to drip a little inside the combustion chamber. Yes I would say its the valve seals if the smoke is blue ,if its black, then it has something to do with fuel.
Sep 7, 2008 at 1:07 PM
